I have an oldish Kenmore gas range with a clock and start/stop timers. I am aware that the stop timer should be pushed in to operate the oven manually. It does not, however, work that way, except when it wants to. It will sometimes work for weeks without a problem, then won't work at all no matter how I twist and turn the knobs. I am fairly close to kicking it.
Kenmore Gas Oven not working properly
Tags: None
There is not much you can do to repair the clock yourself.
If you have a problem with the clock you will have to replace the clock.
John@FreeApplianceRepair.com
www.FreeApplianceRepair.com
