GE Nautilus portable dishwasher problem
  • ponymom
    • Oct 2011
    My portable dishwasher get water and sprays it, but the arms to do the power washing aren't working. The water just gets sprayed around, then drained away. It doesn't make that loud noise, just spraying water around. It was suggested that I need to check the filter, but I have no idea where it is or what I am looking for. HELP!!!
    Model number?
    I'm afraid that is not enough information to identify the appliance in question. What is needed is its exact model number. If you post it we can at least look it up to see what appliance design you're dealing with.
    You can find tips for locating the model and serial number identification tag on your appliances at the following link:
    LINK > Model Number Tag Location Guide
    Appliance411.com
    • ponymom
      • Oct 2011
      The model number is GSC3400F00BL.
        There might be a problem with the piston assembly (see the following link) in 'check valve' in the sump at the base of the tub below the gridded sump cover. They frequently wear out causing either washing or draining problems.
        LINK > Piston and Nut Asm.
        LINK > Sump Cover
        Appliance411.com
