I have a whirlpool front loading dryer model #GGW9250PW2, the dryer is not drying the clothes completely. I have to restart it about three times before they are truly dry. The front panel light never moves from sensing. I have completely cleaned out the exhaust vent on the dryer and the line front the laundry room to the outdoors. Any suggestions?
Announcement
No announcement yet.
Dryer not drying completeley
Try different setting
Try on just a timed dry setting. The results should indicted if it might be a heating problem or not.
Appliance411.com
No but it might just be caused by dirty sensor bars (see the following link) just inside the door. They can get 'gummed up' with residue from dryer sheets, lint, etc.Originally posted by RonpThat seemed to work. is that enough to determine what has gone bad and needs to be replaced?
LINK > Dryer thermostats, safeties and sensors
Otherwise it might be in the electronic dryness control, the wiring to those sensors or a problem at the sensors themselves. Sometimes a coin, etc. can get jammed against them resulting in a short, rendering the moisture control useless.
Appliance411.com
The dryer senses 'dryness' when wet clothes make contact between the two elements. Yes, each has to be connected to wiring to complete the circuit when wet clothing touches both together.I took a look at the sensor bars. I noticed only the top one has an electrical connection on it. Should they both have one?
I'm not sure what Whirlpool recommends but I would think isopropyl alcohol would work.I want to clean them. What type of cleaner should I use?
Appliance411.com
Fixed
Glad to hear it. Thanks for the follow up.I found the second wire for the dry sensor down inside that dryer housing. Once I Cleaned and installed it the dryer started operating like it should.
Appliance411.com
