Frozen Water Leak Around Ice Maker in Kenmore Trio
  • whitedavidp
    • Dec 2008
    • 30
    I have a Kenmore Elite Trio model 795.75543401. We are starting to have trouble with a build up of frozen water in the ice maker. No, not in the ice trays like it should be but outside of that - along the back wall mostly so the ice cube tray cannot slide in all the way.
    We have never replaced the water filter. We do not use the water dispenser very much but perhaps the ice maker does. The water pressure from the dispenser seems fine to me so I would doubt the filter is clogged.
    I just checked the level on the lower glass shelf in the upper section. It is slightly lower on the left than the right but the level bubble is still within the lines. And this has not been a problem until the last few months after maybe 4 year's service. So I doubt that lack of exact level is the culprit.
    Any suggestions on what may be wrong?
    Could the frozen water be the result of the icemaker overfilling?
    Appliance411.com
