I have a Whirlpool side by side refridge #GS6NBEXRL01 w/ice&water dispenser in the door.The ice maker works fine,the water dispenser works fine but the ice dispenser doesn't work.Is this a solenoid problem or something with the touch pad ? 'cause the h20 pad works fine.Any clues? Thanx!
need Whirlpool advice
I don't know of any solenoids used on that model.Is this a solenoid problem
That might be a possibility or a problem at the motor. The dispenser motor could be defective or just jammed up by ice or something.or something with the touch pad ?
Appliance411.com
