I have a kenmore dishwasher with a model number of 665.13572k700. I started a load of dishes the other night and heard dripping while it was running and it was pouring water on the floor. It looks like the machine was just filling itself while running but just never stopped filling and eventually was coming out the door. when i shut the washer off and shut the water valve to it off under the sink i pressed the drain/cancel buttoon and it trained. I have tried jiggling the float while it is filling but nothing seems to stop it even if the washer is not on it fills. Any thoughts?
Kenmore dishwasher 655.13572k700
Tags: None
Model number incorrect
That model number is likely suppose to be 665.13572k700.Originally posted by grainmerchI have a kenmore dishwasher with a model number of 655.13572k700.
If the dishwasher is filling even when it has been disconnected from power, the fill valve (see the following link) behind the lower access panel is likely stuck open and needs to be replaced.It looks like the machine was just filling itself while running but just never stopped filling and eventually was coming out the door.
LINK > Kenmore 665.13572k700 Dishwasher Water Fill Valve
That valve should only open when power is applied to it.
Valve open (ie. letting water through) without power = defective valve.
LINK > How does a water fill valve work
Appliance411.com
.Comment
Channel: Appliances
