Kenmore dishwasher 655.13572k700
  • grainmerch
    • Mar 2012
    I have a kenmore dishwasher with a model number of 665.13572k700. I started a load of dishes the other night and heard dripping while it was running and it was pouring water on the floor. It looks like the machine was just filling itself while running but just never stopped filling and eventually was coming out the door. when i shut the washer off and shut the water valve to it off under the sink i pressed the drain/cancel buttoon and it trained. I have tried jiggling the float while it is filling but nothing seems to stop it even if the washer is not on it fills. Any thoughts?
    when you lift up on the float do you hear a click? may be barely audible but its there.
    • grainmerch
      • Mar 2012
      yes it does make a clicking noise
        ok, so you know the float is working. this is supposed to interrupt the fill solenoid if the tank level gets too high.
        • Dan O.
          • Sep 2003
          • 2167
          Model number incorrect
          Originally posted by grainmerch
          I have a kenmore dishwasher with a model number of 655.13572k700.
          That model number is likely suppose to be 665.13572k700.
          If the dishwasher is filling even when it has been disconnected from power, the fill valve (see the following link) behind the lower access panel is likely stuck open and needs to be replaced.
          LINK > Kenmore 665.13572k700 Dishwasher Water Fill Valve
          That valve should only open when power is applied to it.
          Valve open (ie. letting water through) without power = defective valve.
          LINK > How does a water fill valve work
          JMO
          Appliance411.com
          • grainmerch
            • Mar 2012
            your right the model number is supposed to be 665
