GE Refrigerator ... Sounds funny
  • Dan O.
    replied
    Electronic control failure?
    Originally posted by DD716TED
    General Electric Model Number: GDS20KCSAWW
    That is one of GE's electronically controlled models with a multi-speed evaporator fan motor.
    On many of those models a failure of the fridge's 'mother board' (mounted on the back of the cabinet) causes the evaporator motor to change speeds erratically and/or power multiple speeds at the same time resulting in what many people describe as a 'howling' sound.
    Usually the only way to correct those conditions is to replace the electronic circuit board.
    LINK > GE GDS20KCSAWW 'Mother Board' Electronic Circuit Board
    JMO
    Appliance411.com
    replied
    GE fridge
    the condenser fan motor is almost always a sealed unit, but it uses sleeve bearings. the evaporator/freezer fan motor is an open type fractional horsepower unit with sleeve bearings and fiber spacers. both are porous sintered bronze bearings commonly called OIL-LITE bearings. some bearings are mounted in a self aligning bracket some are fixed so they don't move. almost all use a felt to retain the oil.
    most fractional hp motor armatures have some end play as they seek their magnetic centers when rotating. too much end play the fan can hit something inside.
  • DD716TED
    replied
    Model Number
    General Electric
  • DD716TED
    replied
    Model Number
    Originally posted by Dan O. View Post
    I'm afraid that is not enough information to identify the appliance in question. What is needed is its exact model number. If you post that information we can at least look it up to see what appliance design you're dealing with to try to answer your question.
    You can find tips for locating the model and serial number identification tag on your appliances at the following link:
    LINK > Model Number Tag Location Guide
    Appliance411.com
    The manufacturer id GE
    Sorry I forgot that in my original post.
  • Dan O.
    replied
    Model number?
    3 yr old GE (bottom freezer) refrigerator
    Appliance411.com
  • DD716TED
    started a topic GE Refrigerator ... Sounds funny
    For the past several months, our 3 yr old GE (bottom freezer) refrigerator has been making sounds like a car motor changing speeds... You will notice a sound like a motor running (humming) at a certain RPM then it will slow down and settle at another RPM then it might speed back up or it might stop. After a period of time the process repeats itself. It is always very noticeable. All internal refer / freezer temperatures are OK... Ideas please??
