Hello! I have a very old, very heavily used GE Washing Machine (Model WWA5800MALWH) with an agitator that has gotten progressively more useless over time. At first the agitator would just move weakly and slowly sometimes (especially with a full load of laundry). Then later, with just a moderate amount of laundry, the agitator would usually refuse to move at all unless I gave it a little push to get it started (still moving pretty weakly, but definitely moving.) Sometimes if I couldn't get it to move, I could wait a little while and try again, and then for whatever reason it would move. Today I tried it and got it to agitate pretty well when filled with no laundry and just a small amount of water - but after I added a higher level of water (more weight I guess?), I can't get it moving at all now. The spin/drain cycle has also been pretty slow/weak, though it picks up speed after awhile. I can hear the motor working (seemingly) fine through all this.
I've read enough to know the handful of parts that might be worn out, but I was hoping if I could describe the specific behaviors, it might indicate a single likely solution. Any suggestions?
Thank you!
Thank you!
