I have had this dishwasher almost 10 years, no complaints. It recently started to not drain. It seemed like a one time thing as I was able to get it to drain on 2nd attempt, now it will not drain at all. So I began to take it apart as I did a few searches and wanted to make sure everything was working. I cleaned the filters on the inside, not too dirty. I verified that the impeller blades are good on the inside part of the pump. Pump definitely turns on as I removed the bottom cover. I also looked to see if the hose was clogged (only checked the side closest to the garbage disposal, it was fine). What it seems to do is fill, then when it should drain, it sits and waits then I hear it cycle through a wash again, then it does not drain. I believe the solenoid works, not sure of the impact this has on draining. Any suggestions to troubleshoot?
Mike
Mike
