KitchenAid Dishwasher won't drain completlyafter full wash cycle - Kud102frsso
It is model number Kud102frsso - I have seen the other postings re: a check valve and another referencing a resevoir with junk in it. Could my problem be one or both of these?
Either might cause poor draining, yes, as could a problem in the drain plumbing anywhere between the dishwasher and house plumbing. (The check valve on your model is inside the pump and not external like older K/A dishwashers, which might have been discussed.)
Found out the drain line is not clogged. I syphoned the water out by disconnecting the drain line at the bottom left. It runs a full cycle but leaves 4" or so of water but there are gaps in the cycle for several minutes with no machine noise and no "gurgling" in the kitchen sink we are used to hearing. I am guessing that is the pumpout cycle but nothing is pumping out. It sounds as if i need a drain pump.
There may be several points in a wash cycle where the machine will not be washing or draining. It is not necessarily a sign of a failure. The only time the drain pump might be necessary is if it WAS getting power but NOT running and even then, it might just be jammed up.
Ok the model # GTW330ASK0WW has a very, very, very intermittent problem. About once a month I will come in and find the machine has the wash light on...
