frigidaire dishwasher
  • czar
    I have a problem with my frigidaire dishwasher. As soon as a function is selected the relays on the control board simply chatter. I have changed the board but the same thing happens. Can anyone suggest a soln. could it be because of our 50cycle supply?
  • volts
    • Mar 2004
    • 68
    Czar: AC relays should work normally on 50-60cps. But as in all of life, there may be a flukey exception here. Is line voltage up to snuff? Check the boilerplate: does it specify line frequency? Is it restricted to 60cps only? Is the wiring into the relay board making the proper connections? Contact Frigidaire if necessary.
