trying to locate a water leak on a frigidaire side by side unit
Model: MRS22WNGW6
There is a 1/4 inch tubing exposed at the front, bottom that goes to a length up through the hinge joint
to a water outlet tube in the door dispensing unit.
If I were to pull the quick disconnect union apart, there shouldn't be any pressure in the line,
just whatever is in it - correct?
what are chances that the tubing inside the hinge joint is abraded to the point of leaking
Model: MRS22WNGW6
