my freezer is freezing fine ice maker working water dispenser working but the fridge side is getting very hot the temp on control panel will go up to 99 if plug in long enough about 5-6 hours to get that hot any ideals very little air moving in fridge also if any
GE side by side model# is gss23wstjss freezer cold fridge is hot
Tags: None
Fridge compartment temp above room temperature?!?
The only heat source inside the fridge compartment is the light. There is nothing else that could cause the fridge compartment to increase above ambient room temperature.fridge side is getting very hot the temp on control panel will go up to 99
If the compartment temperature is actually that hot and it is not just an erroneous reading on the display, check to make sure the light isn't staying on.
Appliance411.com
that is what I thought but you can push in the button and all the lights will go out there is also no airflow I ordered the damper assembly that goes inside the fridge will see if that fixes it at the top on the inside of fridge where the air inlet isComment
