Neighbor lady thinks she needs a new stove. Just got it six years ago. Model: RF315PXMW. The issue is that two of the burners are going almost max heat regardless of the knob position. Is this an issue of deteriorating heat elements? Or are the knob controls going bad?
Whirlpool electric stove
Tags: None
Elements only on HIGH
6 years is not very old for an electric range. I very much doubt that this problem would justify replacing the whole appliance.Neighbor lady thinks she needs a new stove. Just got it six years ago.
An element failure would usually result in no heat or in some occasions, reduced heat. The only thing that could cause them to operate on high only, is a failure of their respective control switch as HayZee said.two of the burners are going almost max heat regardless of the knob position. Is this an issue of deteriorating heat elements?
INFO LINK > Electric Range Surface Elements
INFO LINK > Electric Range Surface Element Switch
On that particular range different switches are used for the large and small surface elements (see the following links).
LINK > Element Switch, Small
LINK > Element Switch, Large
A single 'universal' element switch (see the following link) could be used for either large or small elements if needed.
LINK > Universal Infinite Heat Switch
JFYI
Appliance411.com
.Comment
