Badger 5 leaks
  • jck
    Badger 5 leaks
    Hi -
    Just finished reading all messages and threads re: disposals and didn't see the problem I'm having, so here goes.
    Have a Badger 5 at least 6 years old (it was here when we bought the house.) It's leaking from the casing - no water anywhere except on the bottom. It runs fine, the water seems to drain - are there internal seals that need to be replaced? Would it simply behoove me to just replace it?
    Thanks!
    Chris
  • irregularjoe
    • Nov 2003
    • 176
    No, there are no internal seals.
    Yes, replace it.
    The water is running into the motor and the electrical connections,.......not a good idea.
