Kenmore Elite Front Load Washer
  • Gigem085
    • Aug 2011
    • 20
    I have a Kemore Washer Model # 110.47787800 which has stopped and comes up with a F-35 in the display- is this error code and might give a clue on what the issue my be?
    Thank you.
    I haven't encountered such a failure code myself but this is the explanation is from the unit's tech sheet:
    Originally posted by Tech Sheet
    F-35 - The Central Control Unit has detected a malfunction of the analog pressure sensor.
    Possible Causes/Procedure
    1. Check if pressure hose is fixed correctly and without holes or damage.
    2. Check if the airtrap is not blocked.
    3. Check if the hose is not blocked.
    I hope it helps.
    Appliance411.com
    • Gigem085
      • Aug 2011
      • 20
      Thanks, it was the sensor, finally called a repairman.
        Fixed
        Glad to hear you got it going. Thanks for the follow up.
        Appliance411.com
