I hope I got the model number right. The lid will lock and a light comes on but nothing elses happens. A repairman said the main control board 2118940 needs replaced, which means it isn't worth fixing. It is 3 years old. I may have someone else look at it. Do you agree with hime? Thanks.
Maytag MVWC 300xwo won't run
I don't have any personal experience with that Maytag washer design. There should be a 'tech sheet' with the appliance's wiring diagram inside the machine. It should list some diagnostic procedures. I believe the locking mechanism might also be a possibility.
LINK > Maytag MVWC300XW0 Latch Asm.
The replacement control is not that expensive as far as electronic control boards on appliances are concerned. It's definitely not cheap though.A repairman said the main control board 2118940 needs replaced, which means it isn't worth fixing
LINK > Maytag MVWC300XW0 Replacement Electronic Control # W10438123
JFYI
Appliance411.com
That model washer is currently available in the Sears Outlet for $419. You might be able to get a different model washer for $300.Originally posted by ba_50The main control board costs $200 plus. The washer cost about $300. Bob
The control for your machine that I linked to in my previous message is less than $160. If you can do the work yourself it might be a worthwhile repair, if needed.
Appliance411.com
.Comment
Part substitutions are common
No. The original part # 2118940 is now superseded by # W10438123. I wouldn't have thought anyone would still have stock of the original 2118940 part.Originally posted by ba_50Looks like I had the wrong part number
Different suppliers often sell the same parts at different prices. I searched for the cheapest source for it.
.Comment
It can be "electronic" without being "digital"
It is an electronic appliance since it has an electronic control board, which i usually recommend consumers avoid buying, but there are very few totally mechanical models sold any more. It doesn't necessarily have to have a digital display to be electronic although if it does have a digital display it will definitely be electronic.Is this model considered a digital apliance?
But you're not looking to buy it, it is already in your possession??
.Comment
