Amana Gas Dryer rumbling
  • Always something
    • Aug 2011
    • 6
    Hi,
    My Amana gas dryer(lga 10aw) rumbles very loud when spinning. After warm up or about 30 min. later it quiets down somewhat. Is it the bearings or rollers or something else.....what Im I looking for when I get it apart...thanks for helping
    Originally posted by Always something
    Is it the bearings or rollers or something else?
    There are rollers that support the drum at the rear and low friction slides at the front that the drum rides on. If either were worn a rumbling could occur when the drum turns.
    Those components should be inspected for possible problems.
    LINK > Amana LGA10AW Dryer Rear Drum Rollers (2 used)
    LINK > LGA10AW Front Drum Slides (2 req'd)
    There might also be a chance a lint buildup on the felt drum seals or deterioration might also produce such vibrations.
    None of those parts are overly expensive if needed... if looked into in a timely fashion. Letting things like this go can lead to requiring more extensive repairs to correct. I suggest you not put off looking into it too long and/or use it sparingly until it can be.
    Appliance411.com
    • Always something
      • Aug 2011
      • 6
      Thanks so much for your reply. Apon further inspection w/o taking apart yet, the drum feels lose and seems to have a lot of play when I shake it back and forth. Next move is to dive in and see whats what. I'm sure we will be talking again..lol...thx
      • Always something
        • Aug 2011
        • 6
        Thanks Dan, you were right, it was the rear drum rollor on the left side....so I'm replacing both along with the belt...thanks
          It is a common failure point on dryer models that use them.
          I'd suggest replacing both rollers together and replacing the belt won't hurt doing while you're there.
          Let us know how you eventually make it with it.
          Appliance411.com
          • Always something
            • Aug 2011
            • 6
            Replaced both rollors and the belt(under $50)....works like a champ.......thx Dan.
              Fixed!
              Glad to hear it. Thanks for the followup.
              Appliance411.com
