KitchenAid Superba Dishwasher Wont Drain
  • scottcouncilcircle
    • May 2004
    My dishwasher seems to not wont to drain. The dishwasher seems to be stuck in a cycle and wont drain. The dishwahser just keeps filling up with more water and is causing the water to pour out onto the floor. I have tried pushing the cancel drain button but that does not fix the problem.
  • kactuskid
    • Mar 2004
    • 801
    First thing to do is shut off the water that feeds it, you should have an isolation valve. The drain line could be clogged, check the entire tubing that runs from the dishwasher to under the sink.
