Kenmore Oven Timer problems
  • sean
    • May 2004
    On our Kenmore Wall mount electric oven with time bake, self clean features integrate into the electronic clock unit.
    The timer knob is one that clicks and goes up and down.
    The Part number of the entire Timer assembly is 3149809 or 814018. I removed the Timer assembly and removed the knob switch and found that a contact inside of it was broken I want to just replace this one small part, but I can only find the entire assembly which sears wants $271.99 for.
    Is there anyplace I can find the right little switch to solder into place?
    Regards,
    Sean
  • sean
    • May 2004
    Regards,
    Sean
    The oven is around 12 years old if that helps.
    Sean
