I am getting standing water in the bottom of my fridge, I notice it is defrosting a lot more than ever before. Once I came home and water had actually leaked out of the bottom and onto the floor.
Now it seems I need to mop up the water on the bottom (under the crispers) every other day otherwise it accumulates too much. I do not see a drain pan or drain line anywhere that could be clogged.
My fridge is a model Whirlpool Top Mount, model # ET8CHMXKQ0. It is the type that defrosts down the back of the fridge.
Any help is appreciated.
Jim
Jim
. Pouring hot water from the top with a Coat Hanger did the trick after melting all of the ice. We didnt have much luck blowing air through the tube but we only had a air bed pump to blow air.
