One DWM Copeland Compressor for overhauling but the problem we have only 3 old or used conrod and piston with available new piston rings. Is it possible to use it for the mean time, will it last longer?
I would like also to know if you can make a special control to see the correct superheat of the system? Also in addition what is the required reading in megaohm for a compressor to still be in the operating time?
What is also the frequency to have it done by acid test?
Thank you in advance,
Regards,
Serge
Sergio
Regards,
Serge
Sergio
