Badger insinkerator woes
  • asterix007
    Have a Badge insinkerator. It has just stopped working, no sound at all. Water drains perfectly fine. I have tried the following:
    1. Red square reset button at the bottom
    2. Turning with an Allen wrench. I could turn it in either direction easily, though it was not absolutely free.
    Anything else I can try.. I have read all the previous threads on this topic and my problem still did not get solved. Also I have a double sink.
    Any help/suggestions will be most appreciated.
  • asterix007
    Someone please help! I do not wish to waste dollars on costly repairs.
    • ApplianceTech2
      • Jun 2004
      • 25
      Asterix
      I'm not a plumber but I am handy in matters like these. I would not want you to spend money not needed either. But there does come times when it is unavoidable. This may be that time....
      Lets try the basics first.
      Be sure there is electrical power supplied to the disposal. If the unit has it's own power cord, it's plugged into a wall outlet. Be sure the wall switch and outlet have power. Plug a lamp into the outlet and test.
      If power is present, there may be an internal fuse in the disposal. Or the internal rest button may be defective. Worse case is the motor is burned out. Determining the actual cause takes a step by step diagnostic process.
      That model may or may not have a center break away coupling. That slight effort to turn the cutter blades may indicate binding. Which may be caused by a wornout motor. The internal motor magnets will hold the armature too securely to allow the it to turn freely.
      Most likely someone else has other possible causes and ways to test and or fix the machine. I can only offer you generic and or basic possibilities. Be a good suggestion to check back on your question several more times. Likely to get more help from others...
      Helping You Too.
      Good Luck.
      ApplianceTech2
      Natural & Propane Gas Appliance Service Rep.
      Use Logic and Common Sense When All Else Fails
      Good Luck.
      ApplianceTech2
      Natural & Propane Gas Appliance Repair Consultation Service Rep.
