It appeared our Kenmore Elite model 110.20952 992 (made by Whirlpool) top loading washer was leaking.  But on investigation, I found that it was sometimes overfilling resulting in overflow onto the floor.
I started a load with the level set to large (maximum setting). After filling, the wash cycle started. Then, in mid wash cycle, the washer added more water to the (already full) tub, causing the water to overflow onto the floor.
In the sort term, I'm hoping by setting the water level to medium I can prevent this problem from happening. Is the level sensor shot? Should I replace it or what can I do to fix? Since the wash cycle started then filled mid-wash-cycle, I'm thinking there may be a leak in the pressure hose causing the fill switch to open again.
