Can anytell me how to remove the inner door pannel on the freezer side of a GE Profile? Can it even be removed?
GE Profile Door Panel
Welcome MRB068
Depending on the age. I believe the new inner skins are foamed in and can not be removed. The seal if I am not mistaken is the new type put on via a thin channel that the seal would lock into!
For what reason would you want to remove it?
16x80 -
It is a 2001 GE model number pss25sgmabs. I am having problems with my ice dispencer/comtrol module. I believe that it is a problem with the wiring, because when I wiggle the wires that come out from inside the door to the control module it works fine, but I am unsure of how to replace them. The wires are coming out of what appers to be a rubber plug it looks like it should twist a quater turn then pull out but I cannot get it to turn. I could be wrong though it may just be a rubber grommet, in which case I am guessing I am screwed.Comment
