Dishwasher motor failed - how to drain water
  • juubaker
    • Apr 2005
    Hello,
    I have a mid-80s Whirlpool dishwasher that failed
    last night. Motor is burned out.
    The problem is there is some standing water remaining.
    How can I drain the water when the motor is shot?
    Thank you,
    John Baker
    The simplest method is to grab the shop vac and suck it out through the sump from inside.
    You can also disconnect the drain line, then gravity flow as much as possible into a container. Once that is done keep the drain line elevated to trap the water while you pull the dishwasher and carry it outside to replace the motor.
    • juubaker
      • Apr 2005
      Thanks!
      I'm not quite ready to pull it out
      guess now I have a reason to buy a shop-vac :-)
      • SSN596
        • May 2005
        • 136
        Well, since a new dishwasher can be had for less than the cost of a ShopVac, I would get out some sponges!
        Seriously, I hope that you are not considering repairing a 20 year old dishwasher! This is not a prudent expenditure of time or money.
          Besides purchasing a Shop Vac or using a siphon/gravity drain method (which might not be able to clear the whole sump of water), there are inexpensive pump attachments available which connect to a regular drill that can be used for small jobs. (assuming you have a drill handy )
          LINK > http://tinyurl.com/8xspb
          JFYI
