problem with fridgedaire dishwasher
  • Rehan
    • Jun 2005
    Hi i have fridgedaire dishwaher modle#FDB635RFR4
    problem is water is not stop and is very noisy even i trun of the machine water still runs till i turn of the main water line than machine stop so is noise
    If the dishwasher continues to fill even when power is disconnected from it, the water inlet valve has to be stuck open and likely needs to be replaced.
    You can read about how the water valves used on appliances work at the first link below, and see the water valve for your machine at the second.
    - How does a water fill valve work?
    LINK > http://www.appliance411.com/links/jump.cgi?ID=801
    - Frigidaire FDB635RFR4 Water valve
    LINK > http://www.appliance411.com/data.php?rc=1014404
    JFYI
    • Rehan
      • Jun 2005
      Thank You but how i can get to bottom of dishwasher and what is the cause of noies
        Usually the lower access panel comes off. I don't know how much it will help but you can see exploded parts views of your dishwasher at the following link:
        - Frigidaire FDB635RFR4 Exploded View
        LINK > http://www.appliance411.com/data.php?psm=FDB635RFR4
        quote:what is the cause of noise
        Maybe water being forced through a small aperture (maybe in the defective fill valve) but once you get the access panel off, you may be able to pinpoint exactly where the sound is coming from for yourself?
