Ice does not come out.
  • Tom Vista
    • Aug 2005
    When I press the lever to eject ice from my Kenmore side by side model number 59592990, nothing happens. I assumed there is a switch near the lever but I couldn't get the front pannel off. It seems like there are some type of clips at the corner of the plastic pannel. I put a screwdriver behind the pannel and I tried to pop it off, but it didn't seem to want to release so I didn't put a lot of pressure on it.
    Any advice on helping me with my problem would be appreciated.
    tom
    The complete model number looks to be 106.59592990 making it a Whirlpool built model.
    ** I put a screwdriver behind the panel and I tried to pop it off, but it didn't seem to want to release **
    You can see an exploded view diagram of your dispenser mechanism at the following link:
    - Kenmore 106.59592990 Water Dispenser
    LINK > http://tinyurl.com/9crqx
    On some models the front dispenser cover (drawing item # 23) will peel off. The housing mounting screws may then be able to be accessed, if necessary. You can see the lever activation switches (drawing item # 14) at the link below.
    - Dispenser Lever Switches (4)
    LINK > http://www.appliance411.com/data.php?rc=445177
    JFYI
    • Tom Vista
      • Aug 2005
      "On some models the front dispenser cover (drawing item # 23) will peel off."
      Thanks Dan but what does "peel off" mean? As I said, I tried to force it off with a screwdriver but it didn't want to come off.
        ** what does "peel off" mean? **
        That may have been a incomplete description of the process. On some models there are 2 small slots at the bottom of the cover for a screwdriver, etc. to fit into. Those can be used to raise the cover up *slightly*. Once lifted, the cover may be able to be gently pried away from the door from the bottom. Some covers are also held in place with 2-way tape in which case it may have to actually be peeled to get it right off.
        I don't know if that is the way yours is designed or not.
        ** As I said, I tried to force it off with a screwdriver but it didn't want to come off. **
        Just the insert/cover or the whole housing/frame and everything??? The latter would definitely NOT be able to be pried off, just the label/cover to expose the housing's mounting screws beneath. If you're unsure, it might be prudent to leave it to a professional rather than taking a chance on breaking it?
