My Kenmore Ultra Wash III is making a loud roaring/grinding noise during the washing cycle. Is it fatal?
Kenmore Dishwasher Noisy
** Is it fatal? **
It could be if you continue to use it without finding the cause and correcting it.
I'm just curious. Does it make the same sounds with every run?? Or does it seem to change? Does everything seem to work OK? Does it seem to clean the dishes OK? Does all the soap in the dispenser dissolve??
Vinyl and Laserdisc FanVinyl and Laserdisc FanComment
After further investigation, I have decided to just replace the machine. Thank you for trying to help, however. I really appreciate it.quote:Originally posted by X Y Scaling
Did you actually investigate and find the cause? What was it??quote:Originally posted by jhsIII
