Refridgerator Water Leak
  • Ralphsaperstein
    • Oct 2003
    • 6
    All of a suddent the water spout in my refridgerator door is leaking. We use the water (cooled and filtered) frequently.
    I need help stopping the drip.
  • Ralphsaperstein
    • Oct 2003
    • 6
    I meant to add to the previous post. I noticed the dripping after I changed the water filter...
    • 16x80
      • Jul 2003
      • 120
      Ralphsaperstein
      Welcome to the Home Repair Forums
      Those levers hit a micro switch inside the door! It's either on or off no in between! The switch sends power to the valve in the back at the bottom. Its possible that the valve is not closing all the way OR you have to high a water pressure causing the valve to open just slightly.
      16x80
      • Ralphsaperstein
        • Oct 2003
        • 6
        [quote you have to high a water pressure causing the valve to open just slightly.
        16x80
        [/quote]
        Thanks, I turned the water supply valve to almost off. That reduced the drip considerably, but not entirely. At least now it is manageable.
        • 16x80
          • Jul 2003
          • 120
          Manageable yes! Fixed No! I'll bet you have a valve thats not closing all the way!
          If your happy I am happy!
          16x80
          • Ralphsaperstein
            • Oct 2003
            • 6
            Is the valve that you think is not closing all the way difficult to reach and repair/replace? Thus far my examinations of the water dispenser have ended after removing fiberglass insulation and seeing a difficult looking (wires and such) next step.
