My Majic Chef clothes washer is leaking water on the bottom of the tub. Looks to be a gasket that has worn out or the screws need to be tightened. Is this a big problem? Also I need the web site address that Dan O. so kindly gave to me before in the past, that had some good illustrations of different models of washers and break downs of the assembly order. Also had parts list and purchase info.--Thanks, Ray
Leaking Clothes Washer Tub
Tags: None
More information
** Is this a big problem? **
That is diffcult to say without knowing which machine you're working on. Please post the machine's complete model number so we can find out what design of Magic Chef washer you're dealing with.
If you don't know where to find it, you can find tips for locating the model and serial number identification tag on your appliances in the 'Repair Parts' section of my web site linked below.
=D~~~~~~ -
Majic Chef Clothes Washer Leaky Tub
Sorry about not posting the model number of the washer so here it is:
Model# W20JA4 , Serial # AD474770. Thanks--RayComment
wasehr leak
The screws might have loosened off but I've never come across that before nor the gaskets there 'wearing out'. They don't normally need to be replaced except when temperated with (ie. like during service). But anything's possible.Originally posted by Raymond Lee[Magic Chef clothes washer] model# W20JA4 is leaking water on the bottom of the tub. Looks to be a gasket that has worn out or the screws need to be tightened.
You can see the exploded parts views for your model at the following link:
LINK > Magic Chef W20JA4 Exploded Parts Views
JFYI
=D~~~~~~Comment
Channel: Appliances
