have a roper dish washer and the wash cycle works fine but on the rinse cycle the motor just hums. what's up?
dish washer won't rinse
Roper has had numerous different designs of dishwashers over the years. The only way for us to know which particular design of appliance you're dealing with is if you post its model number as was requested in the first form message:Originally posted by duganhave a roper dishwasher
LINK > Please include Make and Model # in post
You mean on drain??but on the rinse cycle the motor just hums.
=D~~~~~~ -
Dishwasehr rinse cycle
A "rinse cycle" consists of several parts; it drains dirty water, it fills with fresh water and then it circulates that clean water through the spray system.
You're saying that just the drain function of the rinse cycle doesn't work? But the motor hums at that time??
When it comes to the spray portion of the rinse cycle, does it spray around the still dirty, un-drained water??
Further, the dishwasher drains normally at the very end of the cycle???
=D~~~~~~Comment
NOT filling on rinse
So it's just not filling again at that time.Originally posted by duganwhen it gets to the rinse cycle it sounds normal but there's no water.
That could be caused by a problem in the water fill valve (see the following link) or the control system. Someone will likely need to check if the water valve is getting power or not, when it should be filling at that point. Water valves can work once or twice but fail but fail to operate after that.
LINK > Roper WU3000V2 Water Fill Valve
If the valve WAS getting power but not allowing water to flow through it, the valve would likely be defective and need to be replaced. If it was NOT getting power at that time, the control system would be suspect.
LINK > How do I test water fill valves?
=D~~~~~~Comment
