Hi all. I do not have a particular problem with any of our appliances as I type this. However, I did have a question reguarding the testing of an appliance motor or compressor. I was wondering if measuring the ohms in the start and run windings of a suspect motor is a "true" test to find out if it is good or bad. I have taken one out of an older washer and was curious. I do not have an amp meter. I was wondering if the motor hummed, or cut off on its overload, etc., if that would show up in a windings test?
Thank you,
Jay
Thank you,
Jay
