I have a Whirlpool washing machine model GSQ9611KQ2 I bought from Sears in 2001. It is not fully draining and makes a noise during the spinning cycle. I did some research and found that I should check the belt, hose, pump filter. I have unplugged the machine and shut-off the water. I think the pump may be clogged with a coin or sock but I am having difficulty opening the cabinet on the machine to access the inside of the machine. Can someone explain how to unhook the white plastic piece (harness?) once I have unscrewed and partially removed the top control panel?
Thanks for your help!
