I have a GE refridgerator, freezer compartment up top, model TBX 16SSXRAD, serial no. GM 795285.
The freezer compartment is freezing. The lower refridgerator compartment for cooling is not coolling. I see condensation on the top of the compartment which simply means there is a wide range temp differential. The light works, and the switch turns off the light when switch is on closed position.
I turned the temp sensor screw to off position and it shut off compressor.
What you guys think? Fan or temp sensor or something?
Thanks in advance.
Thanks in advance.
I hope you can sell off the replacement without too much of a loss.
