My side by side refrigerator is GSS22WGPACC, SN: GF254827,was used for 2 and half years.
Now the refrigerator can keep 30-40F, but the freezer is only 38F near the ice maker. The freezer has 80% freeze food, so at middle of the freezer is about 20F. The control of freezer was set at 9 for two days, refrigerator control is at 5. I can hear fan running in freezer, but I don't know where is the cool air vent.
Before the freezer out off order, the water tank at refrigerator was freeze three times. And food at lower compartment was freeze too. Every time I use low heat air flow to warm the tank. I found the air flow from lower vent at refrigerator is too cold, even I set the control at 1 or 2. Now I put a lot of food in, and use a tape to reduce the the air flow from lower vent at refrigerator,then it can keep 30F. I don't know is there a vent at top of the refrigerator.
Any suggestions? Thanks!
GE has come out with several different 'kits' to help correct those flaws. Either of the problems the following kits were designed to fix might cause the water reservoir to freeze at times.
