Maytag Electric Oven very little heat
  • ohara6z91
    Maytag Model #CWE9000ACB
    Electronic controls no longer available
    Replaced temperature probe did not change anything
    I may change bake element next but seems to check out fine
    I crank temp all the way up to 550degrees and inside temp only goes to about 220degrees. I am at a loss.
    Broil seems fine
    Self Clean seems fine
  • Phelps
    • Jan 2006
    • 157
    Make sure you have 220 volts when volt tested between the two oven element terminals.
    You said you changed the temperature probe? You mean you were just able to buy just the probe and not the entire oven switch it is connected to? You need to make this clear for us.
    IF you changed out the whole component (oven switch/probe) then I would say you have slow voltage condition. HAS to be.
    If you did not change out the entire oven control, then, if you have 220, as I mentioned, the problem would be in the oven control switch. Or, if you have the separate switch for bake, broil, etc., perhaps something is amiss there. Have you tried the broil setting to see what happens at the broil element? Can either of these glo red?
    • ohara6z91
      all digital controls via a control panel. Fixed it by purchasing an entire new oven.
