Sink Vent
  • Bear
    • Oct 2003
    Sink Vent
    The sink vent is leaking(over-flowing) water while my dishwasher is running. One line of the vent goes to the garbage disposal and the other line to the dishwasher. I've had no trouble for 3 years. I don't know if one of drain lines are clogged? Any suggestions out there?
    Many Thanks!
    Bear
  • Jimmer
    • Oct 2003
    • 274
    Bear,
    When you say your 'sink vent' is overflowing... do you mean water comes up into your sink bowl when your dishwasher is draining or do you have pipe/vent somewhere else that you are referring to?
    If you you have a two bowl sink and the water is coming up in the first one (with the disposal and dishwasher connected below it) then you have a blockage on the drain side of the disposal. If it backs up into both sink bowls then the blockage is in the p-trap or downstream from that.
    If you have further info, or I misunderstood you problem please let us know.
    Good luck, Jim
