GE Fridge or Freezer leaking water
  • x2tpd
    • May 2006
    Our GE Side by Side with water in the door .... also has water on the floor
    It has started leaking periodically thru out the day under the freezer side of the unit about 1/2 cup of water?? Any ideas?
    From where?
    Depending on the design of whatever model of fridge you have (tip - post its model number) and where exactly the water is originating, one possibility may be a plugged defrost water drain. Another possibility might be an overflowing drain pan or a leak in the water dispenser or icemaker water supply.
