Make: Magic chef Gas stove & oven
Model: 3488vtv
Serial: 01c33322700
A friend of mine keeps getting an F1 error message on this unit even when it's not in use.
I have 2 questions:
Question 1) Does the troubleshooting scenero below look correct?
Question 2) How do I get access to the back of the LED? There are a lot of fasteners, none of which look like they give acess to the LED reading control panel.
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
1. Disconnect power to stove
2. Gain access to the back of the clock (electronic range control or ERC).
3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
4. Make sure everything is clear and will not short out when power is turned back on.
5. Turn power back on to stove.
6. Watch for the F1 and listen for the beep.
7. If you get the F1 and beep, replace the ERC.
8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!! This has been a new occurrence to us in the last 2-3 years or so.
Model: 3488vtv
Serial: 01c33322700
I have 2 questions:
) and difficult to diagnose, which is why I recommend an extended warranty to anyone whom purchases such appliances (see the following link).
