on the bottom of the disposal is a hole in the center, its takes an allen wrench. (should have been shipped with a new disposal) You can use that to try and un-jam the disposal.
My Garbage disposer just stopped working. I've tried the red reset button. I've used the wrench to spin the blades. But it won't work. All there is is a humming noise. The unit starts heating up. I also noticed some light smoke. The water flows fine. What could be the problem? Any help or suggestions would be appreciated.
That may be my problem as well. I don't recall putting anything in the disposal that could have caused a problem. It just started humming (water running through fine), and then completely quit (no humming). Found the reset button, turned the blades with the allen wrench, and still just humming. How expensive are new disposals?
When I turn my garbage disposal on it makes noise and swirls the water/food around, but none of it goes down the drain. This is affecting the kitchen plumbing. I'm embarassingly enough having to do the dishes in the bathroom sink. What can I do to fix it??? Please help!
