It is a 7 year old GE Profile fridge/freezer, model # TFX27PFSM WW .
Recently, it stopped cooling and exhibited a FF error(freezer) as well as showing the WARM light on the front display panel. In the freezer, I noticed a large block of whitefrost ice at the bottom extending out from the cooling coils.
So, I emptied the fridge/freezer and turned the unit off for 2 days, totally defrosting it. I turned it back on and it seemed to start to get cold again but after a couple days, I got the same error messages and the same block of ice.
Thinking(hoping) it was only something like a broken defroster, I had a service guy come out and he thinks the fridge is a goner, since only the bottom half of the cooling coils freeze up and not the top half? He said that is caused by a freon leak somewhere in the coils... and that it would be cheaper to buy a new fridge rather than replace the entire coil assembly.
I heard that this fridge uses two seperate heaters/defrosters... so I am wondering if could it be just that the top heater/defroster works, and not the bottom one, thereby causing the freezeup?
Has anyone had anything like this happen to them... and if so, what was the problem?
ADDED: the fridge has now been on for a couple of hours now, and still only the bottom two loops of the coil (out of around 30 loops) are frosted and when I touch the pipe at the very top of the coil, it doesn't even seem to be cold to the touch.
Thank you very much for your help!
