One "hot surface" indicator light on my Kitchen Aid (model KECC567B) cooktop stays on all the time. After searching various appliance parts suppliers, I've identified the LED part number as 4454437, but since it's glowing, I would suspect a failed sensor instead of the LED. None of the sites can seem to lead me to a sensor.
Burner indicator light stays on
That is only part of a model number, did you get it right off the appliance's model and serial number identification tag?Originally posted by GaryS
Kitchen Aid cooktop model KECC567B
You can find tips for locating the model number identification tag on your appliances in the 'Repair Parts' section of my web site linked below.
It uses an LED? Most indicator lights on ranges and cooktops are just neon bulbs behind a plastic lens.One "hot surface" indicator light on my stays on all the time. I've identified the LED part number as 4454437, but since it's glowing, I would suspect a failed sensor instead of the LED.
If you post the appliance's complete model number, we'll see if we can look it up.None of the sites can seem to lead me to a sensor.
=D~~~~~~ -
KECC567BBL2
Not every website lists it, but the KECC560B contains the same parts. It's made by Whirlpool.
I won't swear they are LEDs, but the one poor sketch in the only IPB I could find, looks like an LED and there is no lens; the light shines through the ceramic cooktop.
I haven't disassembled the cooktop yet, and am trying to figure out the repair needed before I take it out of service.Comment
Limiter?
That's better.Originally posted by GaryS
KECC567BBL2
There is no such model as "KECC560B", that is just the first part of a model number. Some full model numbers that begin that way include: KECC567BAL0, KECC567BAL1, KECC567BAL2, KECC567BBL0, KECC567BBL1, KECC567BBL2, KECC567BWH0, KECC567BWH1 and KECC567BWH2. Only the complete model number identifies the exact product you have.Not every website lists it, but the KECC560B...
I'm not sure what those are either. They appear to be NLA so I can't even see a picture of them.I won't swear they are LEDs
Which one?One "hot surface" indicator light on my Kitchen Aid cooktop stays on all the time.
On that model design, the hot indicator lights are controlled by the element's limiter switch. Either the one for that indicator has shorted contacts or there may be a short in the cooktop's wiring somewhere. The former is much more common though.
You can see one of the elements used on your model with its limiter, at the following link:
LINK > KitchenAid KECC567BBL2 Left, Rear Element w/Limiter
JFYI
.Comment
Thanks for the info, Dan. It appears that the odds are that I'm going to need the entire element to resolve the problem, and they are pricy. Since the element is operating fine, I don't think I'm going to spend that much money just to make the indicator operate properly. I've gotten used to it being that way, so I guess it's no big deal at this point.
Thanks again for the help.
BTW, I guess I was misinformed about the model number. Someone told me those last letters only described the color of the surface and the mounting ring.Comment
Why? The limiters are available separately. I just didn't have a picture of one of them by itself to show you. Plus I didn't (and still don't) know which one is causing the problem.Originally posted by GaryS
The AL, BL and WH do just indicate the colour, but the number that follows designates changes (besides the colour) in the product from one model to the next. It is also not possible to look up parts many places unless you enter the complete information (whether it just pertains to the colour not not).I guess I was misinformed about the model number. Someone told me those last letters only described the color of the surface and the mounting ring.
JFYI
=D~~~~~~Comment
It's the right-front halogen, but I couldn't find a listing for the limiter.Comment
Element limiter
The limiter for that element is at the following link (although as I said, there is no image of it). Be prepared though, while it is less than 1/2 the price of the corresponding element and limiter assembly, it is still fairly expensive. Many of the other range manufactures don't sell them separately from the element... at any price.Originally posted by GaryS
LINK > KECC567BBL2 Right Front Element Limiter
BTW. When installing one, be careful not to touch the glass of the probe. Some are actually quartz which can be negatively affected by the oils in your skin. Even if not, they are very fragile and easily broken.
JFYI
=D~~~~~~Comment
Saw this old thread, but it seems to address my problem. The 8 inch burner (left rear) needed to be replaced, only one element would get hot. Bought the replacement, WPL-8185649, and installed it. However, it does not get hot. The "hot" indicator goes on immediately, but no heat at the burner. Does the replacement get wired up differently? Any ideas or suggestions?
ThanksComment
That part number looks to be for a dual coil element. Do you mean only one of the two coils of that element worked originally? If so, did anyone test the element to make sure the failure was actually in the element?Originally posted by joesette
The 8 inch burner needed to be replaced, only one element would get hot. Bought the replacement, WPL-8185649
If there were wiring changes required the installation instructions which look to come with the replacement element (see the following link) should have described any changes necessary....installed it. However, it does not get hot. The "hot" indicator goes on immediately, but no heat at the burner. Does the replacement get wired up differently?
LINK > Whirlpool 8185649 Dual Element w/Instructions
I'm afraid I do not have access to those installation instructions to know what they say. Sorry.
=D~~~~~~Comment
Dan,
Thank you for the reply. Other than a digital multimeter, I have no other testing equipment. With the original dual element burner, only the outer element would get hot. The replacement doesn't get hot at all. And, oddly, the "hot" indicator goes on immediately. That was why I thought there might be a wiring change. The burner did not include instructions, other than those for the wire splices if needed.Comment
That would be sufficient to test the individual element coils.Originally posted by joesette
Generally, the two terminals on the limiter which were normally closed (show 0 resistance) when at room temperature would be the ones for power to the element and to the element coil itself. The two terminals for the hot indicator light would be open (show infinite resistance) until the element got hot.The burner did not include instructions, other than those for the wire splices if needed.
JFYI
=D~~~~~~Comment
Dan,
Thanks for your assistance. Turns out it was a simple mistake by a simpe-minded DIYer. The wires do not go to the same terminals! So, making a note of the positions is not enough; you MUST note the terminal numbers and wire color in order to put it make together properly.Comment
Fixed
Glad to hear you figured it out. Thanks for the follow up.
=D~~~~~~Comment
