Kenmore washer does not fill. Agitator starts immediately when washer started. Cycles normally except without water.
Kenmore washer won't fill
Water level control?
It is the water level control switch (see the following link) that is responsible for shutting off the fill process and switching power to the timer for it to advance into the wash cycle where agitation takes place. If its contacts were shorted, it could act as if the washer was full already.Originally posted by 2ff6w9
LINK > How does a washer's water level control work?
If you need any further assistance please post the washer's complete model number so we can look up which design of Kenmore washer you're dealing with. You can find tips for locating the model and serial number identification tag on your appliances in the 'Repair Parts' section of my web site linked below.
JFYI
=D~~~~~~Comment
Channel: Appliances
