Every time I run a wash cycle, it makes it's normal soudns until it runs past "normal wash" to between "normal wash" and "short wash" and it gets just before the middle between those two before the machine locks up. If you listen real close, you can hear a little buzzing. I thought maybe it was doing something, so I let it go and went to bed. The next morning, it hadn't moved and was still buzzing ever so slightly. Any ideas?
Frigidaire Ultra Quiet I dishwasher hanging up?
Model number?
** Frigidaire Ultra Quiet I **
I'm afraid that is not enough information to identify the appliance in question. What is needed is its exact model number.
You can find tips for locating the model and serial number identification tag on your appliances at the following link:
- Model Number Tag Search
LINK > Model Number Tag Search
** it gets just before the middle between those two before the machine locks up. **
By "locks up" I assume you just mean the timer stops progressing through the cycle?
** If you listen real close, you can hear a little buzzing. **
It would likely help to know which exact part on the machine the sound was originating from.
JMO
