leaking garbage disposal
  • milwbrrr
    • Dec 2007
    I have a Badger 5 1/2 H.P. disposal which is leaking from the reset switch and a couple of other spots on the bottom. I've been told it's probably the flywheel seal. Is it worth trying to replace this, or just buy a new one for $80.00+? Thanks!
    Originally posted by milwbrrr
    Badger disposal leaking from the reset switch and a couple of other spots on the bottom. I've been told it's probably the flywheel seal.
    The main seal beneath the rotating shredder, yes.
    If that seal has failed, water has gotten into a lot of places it shouldn't, including the top bearing, motor windings and start switch.
    Just that seal is not available separately anyway, it only comes already installed in the upper end bell housing (along with the bearing). And no, such a job is not usually worthwhile on the cheaper disposer models unless it is still covered by warranty.
