GE GSS251FPD WW Fridge door water not dispensing
  • ktf77
    • Jan 2008
    I have seen this problem on the site before, but I am not sure what do do with my particular GE model. (GSS251FPD WW)
    My fridge does make and dispense ice without a problem. The water does not come out though.
    I did some initial "troubleshooting", and eliminated the possibility of a problem with the water line to the fridge. I also checked the water filter inside the fridge , and that does not seem to be a problem.
    My manual says it could be a frozen reservoir. Does my fridge even have a reservoir? If so, where is it located and how do I thaw it??
    Any help would be greatly appreciated!!
    Model number is actually GSS25IFPDWW
    ** Does my fridge even have a reservoir? **
    Yes, although on your model it might just be a coil of plastic tubing.
    LINK > GSS25IFPDWW "Water Storage Coil"
    ** If so, where is it located? **
    Usually behind the drawers in the fridge compartment.
    ** how do I thaw it?? **
    There is no set procedure AFAIK. Hot water, a hair dryer or even turning the whole fridge off may be possibilities.
    • ktf77
      • Jan 2008
      thanks for the reply!! I still need a bit more advise though...
      I found the reservoir coil... thawed it in hot water, but that did not work.
      I did try the blue connector at the bottom where the freezer door connects to the water tube. It does dispense water from the tube when I depress the dispenser arm.
      So, I know I am close. I have heard that the whole freezer door could be frozen. Could it be anything else? Anything else I can try before I clear out my whole freezer to thaw the whole freezer??
      PS. Thanks for correcting the model number for me... good to know.
        ** I have heard that the whole freezer door could be frozen. **
        Not quite but the water line that is inside the door could be frozen.
        ** Could it be anything else? **
        There shouldn't be as long as water is flowing properly to the door.
        • ktf77
          • Jan 2008
          It worked!
          Well, I finally had a chance to take everything out of the freezer and give it a thaw for a few hours.
          As soon as I tested the dispenser, water began to flow!!!
          Thanks for the help!
            Working
            Glad to hear it. Thanks for the follow up.
