Water Dispenser
  • Ghornet54
    • Mar 2008
    Water Dispenser
    How do you replace a water dispenser on a Whirlpool ED25TEXHW00. The dispenser is broken, but still dispenses water, you have to hold the hose in the glass. Everything works as it should, but I want to replace the dispenser and can't figure how to get the front off to replace the dispenser and hose. I have all the parts, just need a little help.
    Charles
  • Dan O.
    • Sep 2003
    • 2167
    Specifics required
    What part(s) of the dispenser?? AFAIK there is no whole dispenser that can be swapped in and out.
    I don't know if it will help but you can see exploded parts views of your model at the following link:
    LINK > Whirlpool ED25TEXHW00 Exploded Parts Views
    JFYI
    • Ghornet54
      • Mar 2008
      Thanks Dan O. for the quick reply. I was replacing the water dispenser hose and adapter at the water lever inside the door. I found out that you don't need to remove anything but the old dispenser and the hose slides in a conduit. It was simply removing the old hose and threading in the new hose.
      Anyway, thanks for your quick reply. I've got this group saved for any other appliance problems.
      Charles
      • Dan O.
        • Sep 2003
        • 2167
        Fixed
        Glad to hear you figured it out. Thanks for the follow up.
