Hi,
I have a Samsung model DED50LL dehumidifier. When on it beeps twice every two seconds. While doing this, the fan is cyciling on with the beeps. The compressor isn't running though. When I turn off the power, it beeps once every two seconds. It only stops beeping when I unplug it. I unpluged overnight and turned back on the next morning and it was fine. Then was doing it again a day later. I thought it might be the coils freezing up, but I thought it had to be under 65 degrees or so for that to happen. I have a fiished basement and it may be 70 degrees down there but definetly no colder than that. I can't actually see the coils as they are covered. Maybe a next step would be to remove the cover to see if they are freezing?
Nothing in the owners manual or any help from Samsung customer service.
Anyone have any thoughts?
Thank You.
Thank You.
